--- title: "system.sfc.resumeChart" description: "Resumes a chart that was paused." --- # system.sfc.resumeChart > Resumes a chart that was paused. This function is used in **Python Scripting**. ## Description Resumes a chart that was paused. Steps which were previously paused will be resumed, and chart will enter Resuming state. Will throw a KeyError if the ID does not match any running chart instance. ## Client Permission Restrictions [Permission Type](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties): SFC Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.sfc.resumeChart(id)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String | `id` | The ID of the chart instance to resume. ### Returns Nothing ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Code Snippet" # The following attempts to resume a paused SFC. id = "The ID of the SFC you want to resume" system.sfc.resumeChart(id) ```
