--- title: "system.sfc.getRunningCharts" description: "Retrieves information about running charts." --- # system.sfc.getRunningCharts > Retrieves information about running charts. This function is used in **Python Scripting**. ## Description Retrieves information about running charts. Can search all running charts, or be filtered charts at a specific path. This function will return charts that are in a Paused state. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.sfc.getRunningCharts([chartPath])` ### Parameters | Type | Parameter | Description | | ------- | ------- | ------ | | String | `chartPath` | The path to a chart to filter on: i.e., "folder/chartName". If specified, only charts at the path will be included in the returned dataset. If omitted, the function will return data for all active charts. | ### Returns **Dataset** - A dataset with information on the active chart. Contains the following columns: - instanceId - the chart instance, or UUID of the chart. - chartPath - The path to the chart. - startDate - A date object noting when the chart instance started. - startedBy - The name of the user that started the chart. - chartState - The current state of the chart. Possible states are "Running" and "Paused". - keyParamName - Name of the chart's Key Parameter. Returns None if a Key Parameter is not defined. - keyParamValue - Value of the chart's Key Parameter. Returns None if a Key Parameter is not defined. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1 - Check All Running Charts" # This example will check for all running charts, and return a formatted string detailing each chart instance. # Check for all running charts. The path may be specified as a string to filter the results. data = system.sfc.getRunningCharts() # Create a string to append chart data to. The "\n" is a new line character. chartData = "The following charts are running:\n" # Iterate through each chart for row in range(data.rowCount): # Extract the instanceId and chartPath values from the current row runningChartId = data.getValueAt(row, "instanceId") runningChartPath = data.getValueAt(row, "chartPath") # Append a string to chartData with the values extracted above chartData += "Id: %s, Path: %s\n" % (runningChartId, runningChartPath) # Print the string of chart Id's and Paths print chartData ``` ```python title="Example #2 - Retrieve Chart 'instanceId' Using 'chartPath'" # This example will return the instanceId of chart instances with a specific chartPath. # A valid path must be defined for this example. # Return data for running instances at a specific path. "folder/myChart" should be replaced with a valid path. data = system.sfc.getRunningCharts("folder/myChart") # Initialize a list to contain all instance Ids chartIds = [] # Iterate through each chart, and fetch the instanceId for row in range(data.rowCount): chartIds.append(data.getValueAt(row, "instanceId")) # Print the chartIds list print chartIds ```
