--- title: "system.serial.sendBreak" description: "Sends a break signal for approximately millis milliseconds." --- # system.serial.sendBreak > Sends a break signal for approximately millis milliseconds. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.serial.sendBreak(port, millis)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `port` | The name of the serial port, e.g., "COM1" or "dev/ttyS0". Integer| `millis` | Approximate length of break signal, in milliseconds. ### Returns Nothing ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Code Snippet" # This example will send a break signal to a port called "COM1" for 10000 milliseconds. port = "COM1" millis = 10000 system.serial.sendBreak(port,millis) ```
