--- title: "system.serial.configureSerialPort" description: "Configure a serial port for use in a later call." --- # system.serial.configureSerialPort > Configure a serial port for use in a later call. This function is used in **Python Scripting**. ## Description Configure a serial port for use in a later call. This only needs to be done once unless the configuration has changed after the initial call. All access to constants must be prefixed by " system.serial. ". ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax :::tip This function accepts [keyword arguments](platform\scripting\python-scripting\user-defined-functions.md#keyword-arguments). ::: `system.serial.configureSerialPort(port, [bitRate], [dataBits], [hardwareFlowControl], [parity], [stopBits])` ### Parameters | Type | Parameter | Description | | ------- | ------- | ------ | | String |`port` | The name of the serial port, e.g., "COM1" or "/dev/ttyS0". This parameter is required.| | Integer | `bitRate` | Configure the bit rate. Valid values are defined by the following constants [optional]: `system.serial.BIT_RATE_110, system.serial.BIT_RATE_150`, `system.serial.BIT_RATE_300, system.serial.BIT_RATE_600`, `system.serial.BIT_RATE_1200, system.serial.BIT_RATE_2400`, `system.serial.BIT_RATE_4800, system.serial.BIT_RATE_9600`, `system.serial.BIT_RATE_19200, system.serial.BIT_RATE_38400`, `system.serial.BIT_RATE_57600, system.serial.BIT_RATE_115200`, `system.serial.BIT_RATE_230400, system.serial.BIT_RATE_460800`, `system.serial.BIT_RATE_921600`| | Integer | `dataBits` | Configure the data bits. Valid values are defined by the following constants [optional]: `system.serial.DATA_BITS_5, system.serial.DATA_BITS_6`, `system.serial.DATA_BITS_7, system.serial.DATA_BITS_8`| | Boolean | `hardwareFlowControl` | Configure hardware flow control. On or off. [optional]| | Integer | `parity` | Configure parity. Valid values are defined by the following constants [optional]:`system.serial.PARITY_EVEN, system.serial.PARITY_ODD`, `system.serial.PARITY_MARK, system.serial.PARITY_SPACE, system.serial.PARITY_NONE`| | Integer | `stopBits` | Configure stop bits.Valid values are defined by the following constants [optional]:`system.serial.STOP_BITS_1, system.serial.STOP_BITS_2` | :::note The serial library was updated in 8.0. Any constants, like HANDSHAKE, that do not have an equivalent value will result in a value of 0. ::: ### Returns **SerialConfigurator** - A SerialConfigurator object with exposed functions that can be used to configure the serial port instead of, or in addition to, the arguments passed to `configureSerialPort`. ### Scope Gateway, Vision Client, Perspective Session ## SerialConfigurator Methods Below is a listing of methods on the SerialConfigurator object. All methods return the original SerialConfigurator object, but with a modified parameter value. For a list of possible values, see the appropriate parameter on the function description above. |Method| Description| |--|--| |setBitRate| Sets the bit rate on the SerialConfigurator.| |setDataBits| Sets the data bits on the SerialConfigurator.| |setParity |Sets the parity on the SerialConfigurator.| |setStopBits| Sets the stop bits on the SerialConfigurator.| |setFlowControl |Sets the flow control on the SerialConfigurator.| |setHandshake| Sets the handshake on the SerialConfigurator.| |setHardwareFlowControl| Sets the hardware flow control on the SerialConfigurator.| ## Code Examples ```python title="Example #1 Configuring Serial Port" # Configure a serial port using keyword args. # The "port" keyword is mandatory. system.serial.configureSerialPort(\ port="COM1",\ bitRate=system.serial.BIT_RATE_9600,\ dataBits=system.serial.DATA_BITS_8,\ handshake=system.serial.HANDSHAKE_NONE,\ hardwareFlowControl=False,\ parity=system.serial.PARITY_NONE,\ stopBits=system.serial.STOP_BITS_1) ``` ```python title="Example #2 Configuring Serial Port" # Configure a serial port using a SerialConfigurator (returned by configureSerialPort()): system.serial.configureSerialPort("COM1")\ .setBitRate(system.serial.BIT_RATE_9600)\ .setDataBits(system.serial.DATA_BITS_8)\ .setHandshake(system.serial.HANDSHAKE_NONE)\ .setHardwareFlowControl(False)\ .setParity(system.serial.PARITY_NONE)\ .setStopBits(system.serial.STOP_BITS_1) ```
