--- title: "system.security.validateUser" description: "Tests credentials (username and password) against an authentication profile." --- # system.security.validateUser > Tests credentials (username and password) against an authentication profile. This function is used in **Python Scripting**. ## Description Tests credentials (username and password) against an authentication profile. Returns a boolean based upon whether or not the authentication profile accepts the credentials. If the authentication profile name is omitted, then the current project's default authentication profile is used. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax (Client) `system.security.validateUser(username, password, [authProfile], [timeout])` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `username` | The username to validate String| `password` | The password for the user String| `authProfile` | The name of the authentication profile to run against. Leaving this out will use the project's default profile. [optional] Integer| `timeout` | Timeout for Client-to-Gateway communication. Default is 60,000ms. [optional] ### Returns **Boolean** - False if the user failed to authenticate; True if the username/password was a valid combination. ### Scope Vision Client ## Syntax (Gateway) `system.security.validateUser(username, password, [authProfile])` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `username` | The username to validate. String| `password` | The password for the user. String| `authProfile` | The name of the authentication profile to run against. Optional. Leaving this out will use the project's default profile. [optional] ### Returns **Boolean** - False if the user failed to authenticate; True if the username/password was a valid combination. ### Scope Gateway, Perspective Session ## Code Example ```python title="Code Snippet" # This would require the current user to enter their password again before proceeding. currentUser = system.security.getUsername() password = system.gui.passwordBox("Confirm Password") valid = system.security.validateUser(currentUser, password) if valid: # do something else: system.gui.errorBox("Incorrect password") ```
