--- title: "system.secsgem.enableDisableEquipment" description: "Enables or disables a Tuple of equipment connections from a script." --- # system.secsgem.enableDisableEquipment > Enables or disables a Tuple of equipment connections from a script. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions [Permission Type](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties): SECS/GEM Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when called in the Gateway scope. ## Syntax `system.secsgem.enableDisableEquipment(enable, names)` ### Parameters Type | Parameter | Description ------- | ------- | ------ Boolean| `enable` | Set to True to enable equipment connections, or set to False to disable them. Tuple| `names` | A Tuple of Strings. Each String should match an Equipment Connection configured on the Gateway. If this parameter contains the name of an Equipment Connection that does not exist, then a message will be included in the List returned by this function. ### Returns **List** - A List of unicode strings. Each string contains a message about an equipment connection that could not be enabled/disabled. If the list is empty, then all specified equipment connections were successfully modified. ### Scope Vision Client ## Code Examples ```python title="Code Snippet" # Executing this example script will attempt to disable two Equipment Connections # Create a Python Tuple of equipment names to disable. equipmentNames = ("ToolOne","ToolTwo") # Invoke the Function result = system.secsgem.enableDisableEquipment(False, equipmentNames) # Print the results of any equipment connections that could not be modified. print result ```
