--- title: "system.report.executeReport" description: "Immediately executes an existing report and returns a List[Byte] of the output." --- # system.report.executeReport > Immediately executes an existing report and returns a List[Byte] of the output. This function is used in **Python Scripting**. ## Description Immediately executes an existing report and returns a List[Byte] of the output. Throws an IllegalArgumentException when any of the following occurs: If the file type is not recognized, path does not exist, project does not exist. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax :::note This function accepts [keyword arguments](platform\scripting\python-scripting\user-defined-functions.md#keyword-arguments). ::: `system.report.executeReport(path, project, [parameters], fileType)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `path` | The path to the existing report. String| `project` | The name of the project where the report is located. Optional in client scope. Dictionary[String, Integer]| `parameters` | A dictionary of parameter overrides, in the form name:value. [optional] String| `fileType` | The file type the resulting byte array should represent. Defaults to "pdf". Not case-sensitive ### Returns **List[Byte]** - A byte array of the resulting report. ### Scope Gateway, Vision Client, Perspective Session ## Values for the fileType Parameter Acceptable values are: - pdf - html - csv - rtf - jpeg - png - xml - xls - xlsx :::note xls and xlsx Formats The xls and xlsx format options may return less than pixel perfect results. This is due to how many spreadsheet programs interpret the resulting file. As a result, the pdf format is recommended in most cases. ::: ## Code Example ```python title="Code Snippet - Executing Report" # Executes the report, overriding two parameters. overrides = {"myStringParam":"Hello world", "myIntParam":3} bytesArray = system.report.executeReport(path="My Path", project="MyProject", parameters=overrides, fileType="pdf") ```
