--- title: "system.perspective.closeSession" description: "Closes the Perspective Session with the given sessionID or the current Session if no ID is provided." --- # system.perspective.closeSession > Closes the Perspective Session with the given sessionID or the current Session if no ID is provided. This function is used in **Python Scripting**. ## Description Closes the Perspective Session with the given sessionID or the current Session if no ID is provided. If a message is provided, it is displayed on the page when the Session closes. Otherwise the default message (set in the [Project properties](ignition-modules\perspective\perspective-project-properties.md#perspective-general-properties)) is displayed. :::note In the Perspective App, the user is returned to the launch screen. ::: ## Syntax `system.perspective.closeSession([message], [sessionId])` ### Parameters Type | Parameter | Description ------- | ------- | ------- String | `message` | The message to display when the Session closes. If omitted, the default message (set in the [Project properties](ignition-modules\perspective\perspective-project-properties.md#perspective-general-properties)) is shown. [optional] String | `sessionId` | Identifier of the Session to be closed. If omitted, the current sessionId is used. [optional] ### Returns Nothing ### Scope Gateway, Perspective Session :::note This function will only work in the Gateway scope if `sessionId` is supplied to the call. ::: ## Code Examples ```python title="Code Snippet" # Closes the Session with the given sessionId. system.perspective.closeSession('Your Session has ended.','2e1c98a8-182e-43ce-84e8-a71d441c2cce') ```
