--- title: "system.perspective.alterDock" description: "Changes configuration of a specified dock on a Perspective page." --- # system.perspective.alterDock > Changes configuration of a specified dock on a Perspective page. This function is used in **Python Scripting**. ## Description ## Syntax :::tip This function accepts [keyword arguments](platform\scripting\python-scripting\user-defined-functions.md#keyword-arguments). ::: `system.perspective.alterDock(dockId, [config], [sessionId], [pageId])` ### Parameters | Type | Parameter | Description | |--------|------------|-------------| | String | `dockId` | The unique identifier of the dock to be modified. If no dock with the specified ID exists on the current page, a warning will be logged to the console. | | PyDictionary | `config` | A PyDictionary containing the dock configuration to be applied when the script is run. If omitted, the dock configuration remains unchanged. [optional]The following properties can included in the `config` object:view: The view to be displayed in the dock.viewParams: A dictionary of name and value pairs to be passed as parameters to the view.display: The display state of the dock. Accepted values are:visibleonDemandautoresizable: The resizable status of the dock.modal: The modal status of the dock.content: How the dock should interact with the main content. Accepted values are:pushcoverautosize: The width or height of the dock, depending on orientation.autoBreakpoint: The minimum page width at which a dock with "display = auto" remains visible. If the session width is smaller than this value, the dock is hidden and can be displayed on demand.anchor: Determines whether the docked view remains visible while scrolling. Only available for North-docked views. Accepted values are:fixedscrollablehandle: Controls the visibility of a handle that allows users to expand or collapse the dock. Accepted values are:showhideautoHidehandleIcon: The path to an icon used to represent the dock when it is hidden. | | String | `sessionId` | The ID of the session in which the dock modification is applied. If omitted, the modification applies to the current session. [optional] | | String | `pageId` | The ID of the page where the dock is located. If omitted, the modification applies to the current page. [optional] | ### Returns Nothing ### Scope Perspective Session ## Code Examples ```python title="Code Snippet" # Change the size of a dock with the id 'my-dock-id' system.perspective.alterDock('my-dock-id', { 'size': 500 } ) ```
