--- title: "system.opcua.addConnection" description: "Adds a new OPC UA connection." --- # system.opcua.addConnection > Adds a new OPC UA connection. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.opcua.addConnection(name, description, discoveryUrl, endpointUrl, securityPolicy, securityMode, settings)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `name` | Name to assign to the new connection. String| `description` | Description assigned to the new OPC UA connection. String| `discoveryUrl` | Endpoint URL to use for discovery services. String| `endpointUrl` | Endpoint URL to use for session services. String| `securityPolicy` | The name of the SecurityPolicy to use. See the Security Policy table below for possible values. String| `securityMode` | The name of the MessageSecurityMode to use. See the Message Security Mode table below for possible values. Dictionary[String, Any]| `settings` | A dictionary of additional settings to apply to the connection. See the Settings table for a table of possible keys. ### Returns Nothing ### Scope Gateway, Perspective Session ### Security Policy Below is a listing of supported values for the securityPolicy argument: * None * Basic128Rsa15 * Basic256 * Basic256Sha256 * Aes128_Sha256_RsaOaep * Aes256_Sha256_RsaPss ### Message Security Mode Below is a listing of supported values for the messageSecurityMode argument: * None * Sign * SignAndEncrypt ### Settings Below is a listing of supported values for the settings argument: | Key | Data Type | | ---------------------------- | --------- | | ENABLED | Boolean | | DISCOVERYURL | String | | ENDPOINTURL | String | | SECURITYPOLICY | String | | SECURITYMODE | String | | USERNAME | String | | PASSWORD | String | | HOSTOVERRIDE | String | | CONNECTTIMEOUT | Integer | | ACKNOWLEDGETIMEOUT | Integer | | REQUESTTIMEOUT | Integer | | SESSIONTIMEOUT | Integer | | MAXPEROPERATION | Integer | | MAXREFERENCESPERNODE | Integer | | MAXPENDINGPUBLISHREQUESTS | Integer | | MAXNOTIFICATIONSPERPUBLISH | Integer | | MAXMESSAGESIZE | Integer | | MAXARRAYLENGTH | Integer | | MAXSTRINGLENGTH | Integer | | TYPEDICTIONARYFRAGMENTSIZE | Integer | | KEEPALIVEFAILURESALLOWED | Integer | | KEEPALIVEINTERVAL | Integer | | KEEPALIVETIMEOUT | Integer | | BROWSEORIGIN | String | | CERTIFICATEVALIDATIONENABLED | Boolean | | KEYSTOREALIAS | String | | KEYSTOREALIASPASSWORD | String | | FAILOVERENABLED | Boolean | | FAILOVERTHRESHOLD | Integer | | FAILOVERDISCOVERYURL | String | | FAILOVERENDPOINTURL | String | | FAILOVERHOSTOVERRIDE | String | ## Code Examples ```python title="Example #1" # The following could be used to connect to Ignition's OPC UA server. system.opcua.addConnection( "test", "test desc", "opc.tcp://localhost:62541/discovery", "opc.tcp://localhost:62541", "Basic256Sha256", "SignAndEncrypt", { "username":"opcuauser", "password":"password" } ) ```
