--- title: "system.opchda.readRaw" description: "Reads raw values from the OPC-HDA server." --- # system.opchda.readRaw > Reads raw values from the OPC-HDA server. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.opchda.readRaw(serverName, itemIds, startDate, endDate, maxValues, boundingValues)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `serverName` | The name of the defined OPC-HDA server to read. List| `itemIds` | A list of item ids to read. Object| `startDate` | The starting date/time of the query. Object| `endDate` | The ending date/time of the query. Integer| `maxValues` | The maximum number of values to return. 0 or less means unlimited. Boolean| `boundingValues` | A boolean indicating whether or not the "bounding values" should be included in the result set. The bounding values provide a value exactly at the start and end dates, but may be resource-intensive to retrieve. ### Returns **List[ReadResults]** - A list of read results which is one-to-one with the item IDs passed in. The ReadResult object has a 'serviceResult' quality property that indicates whether the call was successful, and is itself a list of QualifiedValues. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1" # This example will read raw data from a Matrikon server between two specified dates. # Declare start and end dates start = system.date.getDate(2022, 3, 14) end = system.date.now() # Call system function and print results readValue = system.opchda.readRaw("Matrikon",[1],start,end,0,False) print readValue ```
