--- title: "system.opchda.readProcessed" description: "Reads processed values from the OPC-HDA server." --- # system.opchda.readProcessed > Reads processed values from the OPC-HDA server. This function is used in **Python Scripting**. ## Description Reads processed values from the OPC-HDA server. Processed values are calculated values, based on the aggregate function requested for each item. The list of aggregates can be obtained by calling [system.opchda.getAggregates()](appendix\scripting-functions\system-opchda\system-opchda-getAggregates.md). ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.opchda.readProcessed(serverName, itemIds, startDate, endDate, resampleIntervalMS, aggregates)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `serverName` | The name of the defined OPC-HDA server to read. List[String]| `itemIds` | A list of item ids to read. Any| `startDate` | The starting date/time of the query. Any| `endDate` | The ending date/time of the query. Integer| `resampleIntervalMS` | The interval, in milliseconds, that each value should cover. List[Integer]| `aggregates` | A list which should be one-to-one with the item ids requested, specifying the integer id of the aggregation function to use. The aggregation ids are defined in the OPC-HDA specification. The list of aggregates can also be obtained by calling [system.opchda.getAggregates()](appendix\scripting-functions\system-opchda\system-opchda-getAggregates.md). ### Returns **List[ReadResults]** - A list of read results which is one-to-one with the item IDs passed in. The ReadResult object has a 'serviceResult' quality property that indicates whether the call was successful, and is itself a list of QualifiedValues. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1" # This example will read processed data from a Matrikon server between two specified dates. # Declare start and end dates start = system.date.getDate(2022, 3, 14) end = system.date.now() # Call system function and print results readValue = system.opchda.readProcessed("Matrikon",[1],start,end,1000,[1]) print readValue ```
