--- title: "system.opchda.readAttributes" description: "Reads the specified attributes for the given item over a time range." --- # system.opchda.readAttributes > Reads the specified attributes for the given item over a time range. This function is used in **Python Scripting**. ## Description Reads the specified attributes for the given item over a time range. Attributes and their IDs are defined in the OPC-HDA specification, and can be discovered by calling [system.opchda.getAttributes()](appendix\scripting-functions\system-opchda\system-opchda-getAttributes.md). ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.opchda.readAttributes(serverName, itemId, attributeIds, startDate, endDate)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `serverName` | The name of the defined OPC-HDA server to read. String| `itemId` | The itemID to retrieve attributes for. List[String]| `attributeIds` | The integer IDs of the attributes to read. The attribute ids are defined in the OPC-HDA specification. The attributes can also be obtained by calling [system.opchda.getAttributes()](system-opchda-getAttributes.md). Some servers may not support all attributes. String (can be other data types, such as int)| `startDate` | The starting date/time of the query. String (can be other data types, such as int)| `endDate` | The ending date/time of the query. ### Returns **List[ReadResults]** - A list of read results which is one-to-one with the requested attributes. The ReadResult object has a serviceResult quality property that indicates whether the call was successful, and it is itself a list of QualifiedValues. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1" # This example will get user-specified attributes over a period of time from a Matrikon OPC HDA explorer. # Declare start and end dates start = system.date.getDate(2022, 10, 24) end = system.date.getDate(2022, 10, 24) # Call the system function hda = system.opchda.readAttributes('Matrikon HDA','1',[1],start,end) print hda ```
