--- title: "system.opchda.isServerAvailable" description: "Checks to see if the specified OPC-HDA server is defined, enabled, and connected." --- # system.opchda.isServerAvailable > Checks to see if the specified OPC-HDA server is defined, enabled, and connected. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.opchda.isServerAvailable()` ### Parameters | Type | Parameter | Description | | ------- | ------- | ------ | | String | `serverName` | The name of the OPC-HDA server to check. | ### Returns **Boolean** - Will be true if the server is available and can be queried, false if not. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1" # This example will check to see if there is an OPC HDA server called "ServerName" available. system.opchda.isServerAvailable(“ServerName”) ```
