Version: 8.1
system.opchda.isServerAvailable
Checks to see if the specified OPC-HDA server is defined, enabled, and connected.
system.opchda.isServerAvailable()
StringserverNameThe name of the OPC-HDA server to check.
Boolean - Will be true if the server is available and can be queried, false if not.
Example #1
# This example will check to see if there is an OPC HDA server called "ServerName" available.
system.opchda.isServerAvailable(“ServerName”)
