--- title: "system.opchda.insert" description: "Insert values on the OPC-HDA server." --- # system.opchda.insert > Insert values on the OPC-HDA server. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions [Permission Type](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties): OPC Server Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.opchda.insert(serverName, itemId, value, date, quality)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `serverName` | The name of the defined OPC-HDA server. String| `itemId` | The item ID to perform the operation on. Any| `value` | The value to insert. Any| `date` | The date to insert. Integer| `quality` | The quality to insert. ### Returns **QualityCode** - The result of the insert. See [Scripting Object Reference](../../reference-pages/scripting-object-reference/scripting-object-reference.md#qualitycode). ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1" # This will insert the value for May 28th, 2014 at 5:42:33. date = system.date.getDate(2014, 4, 28) datetime = system.date.setTime(date, 5, 42, 33) system.opchda.insert("MyHistoryServer", "MyItemId", 42.5, datetime, 192) ```
