system.opchda.insert
Descriptionβ
Insert values on the OPC-HDA server.
Permission Type: OPC Server Management
Syntaxβ
system.opchda.insert(serverName, itemId, value, date, quality)
Parametersβ
| String | serverName | The name of the defined OPC-HDA server. |
| String | itemId | The item ID to perform the operation on. |
| Any | value | The value to insert. |
| Any | date | The date to insert. |
| Integer | quality | The quality to insert. |
Returnsβ
QualityCode - The result of the insert. See Scripting Object Reference.
Scopeβ
Code Examplesβ
Example #1
# This will insert the value for May 28th, 2014 at 5:42:33.
date = system.date.getDate(2014, 4, 28)
datetime = system.date.setTime(date, 5, 42, 33)
system.opchda.insert("MyHistoryServer", "MyItemId", 42.5, datetime, 192)
