system.opchda.getAttributes
Descriptionβ
Queries the given server for the item attributes that are available with system.opchda.readAttributes().
Syntaxβ
system.opchda.getAttributes(serverName)
Parametersβ
| String | serverName | The name of the defined OPC-HDA server to query. |
Returnsβ
List[AttributeInfo] - A list of AttributeInfo objects. See the AttributeInfo Methods panel for a listing of available methods.
Scopeβ
AttributeInfo Methodsβ
| Method | Description | Return Type |
| getId() | Returns the ID of the attribute. | Integer |
| getName() | Returns the name of the attribute. | String |
| getDesc() | Returns the description of the attribute. | String |
| getType() | Returns the data type of the attribute. | Datatype |
Code Examplesβ
Code Snippet
# This example gets the description of a Matrikon OPC HDA explorer
# Declare a OPC HDA variable using the system function and prints out the results
opcHda = system.opchda.getAttributes('Matrikon HDA')
print opcHda
# Use the getDesc() method to get the description of the attribute and print out the result
getDesc = hda[1].getDesc()
print getDesc
