--- title: "system.opc.writeValue" description: "Writes a value directly through an OPC server connection synchronously." --- # system.opc.writeValue > Writes a value directly through an OPC server connection synchronously. This function is used in **Python Scripting**. ## Description Writes a value directly through an OPC server connection synchronously. Will return an OPC UA status code object. You can quickly check if the write succeeded by calling isGood() on the return value from this function. Supplying a QualifiedValue to this system function will cause the DataValue to include the QualifiedValue's corresponding StatusCode when the DataValue is sent to the server. ## Client Permission Restrictions [Permission Type](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties): OPC Server Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.opc.writeValue(opcServer, itemPath, value)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `opcServer` | The name of the OPC server connection in which the item resides. String| `itemPath` | The item path, or address, to write to. Object| `value` | The value to write to the OPC item. ### Returns **Quality** - The status of the write. Use returnValue.isGood() to check if the write succeeded. Refer to the list of [writeValue](https://sdk.inductiveautomation.com/javadoc/ignition81/latest/com/inductiveautomation/ignition/common/model/values/QualityCode.html) objects. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Code Snippet - Writing to an OPC Value" # This example will write to an OPC Tag that is on a provider called SLCSim # Declare the server name server = "Ignition OPC UA Server" # Declare the Tag path path = "[SLCSim]_Meta:N7/N7:0" # Declare the system function parameters oldQualifiedValue = system.opc.readValue(server, path) newValue = oldQualifiedValue.getValue() + 1 # Call the system function and print out results returnQuality = system.opc.writeValue(server, path, newValue) if returnQuality.isGood(): print "Write was successful" else: print "Write failed" ```
