--- title: "system.opc.readValue" description: "Reads a single value directly from an OPC server connection." --- # system.opc.readValue > Reads a single value directly from an OPC server connection. This function is used in **Python Scripting**. ## Description Reads a single value directly from an OPC server connection. The address is specified as a string, for example, [MyDevice]N11/N11:0The object returned from this function has three attributes: value, quality, and timestamp. The value attribute represents the current value for the address specified. The quality attribute is an OPC UA status code. You can easily check a good quality vs a bad quality by calling the isGood() function on the quality object. The timestamp attribute is Date object that represents the time that the value was retrieved at. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.opc.readValue(opcServer, itemPath)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `opcServer` | The name of the OPC server connection in which the item resides. String| `itemPath` | The item path, or address, to read from. ### Returns **QualifiedValue** - A [QualifedValue](https://sdk.inductiveautomation.com/javadoc/ignition81/latest/com/inductiveautomation/ignition/common/model/values/QualifiedValue.html) object that contains the value, quality, and timestamp returned from the OPC server for the address specified. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Code Snippet" server = "Ignition OPC UA Server" path = "[SLCSim]_Meta:N7/N7:0" qualifiedValue = system.opc.readValue(server, path) print "Value: " + str(qualifiedValue.getValue()) print "Quality: " + qualifiedValue.getQuality().toString() print "Timestamp: " + qualifiedValue.getTimestamp().toString() ```
