--- title: "system.opc.browseSimple" description: "Allows browsing of OPC servers in the runtime returning a list of tags." --- # system.opc.browseSimple > Allows browsing of OPC servers in the runtime returning a list of tags. This function is used in **Python Scripting**. ## Description Allows browsing of OPC servers in the runtime returning a list of tags. browseSimple() takes mandatory parameters, which can be null, while browse() uses keyword-style arguments. The spelling on the `opcServer` and `device` parameters must be exact. :::caution This function performs a fully recursive browse that can't be terminated, which can be especially problematic in larger systems. It is highly advised to use [system.opc.browseServer](system-opc-browseServer.md) instead since recursion with that function is driven by subsequent calls. ::: ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.opc.browseSimple(opcServer, device, folderPath, opcItemPath)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `opcServer` | The name of the OPC server to browse String| `device` | The name of the device to browse String | `folderPath` | Filters on a folder path. Use * as a wildcard for any number of characters and a ? for a single character. String| `opcItemPath` | Filters on a OPC item path. Use * as a wildcard for any number of characters and a ? for a single character. ### Returns **OPCBrowseTag[]** - An array of [OPCBrowseTag](https://sdk.inductiveautomation.com/javadoc/ignition81/latest/com/inductiveautomation/ignition/common/script/builtin/ialabs/OPCBrowseTag.html) objects. OPCBrowseTag has the following functions: getOpcServer(), getOpcItemPath(), getType(), getDisplayName(), getDisplayPath(), getDataType(). ### Scope Gateway, Vision Client, Perspective Session ## Code Example ```python title="Code Snippet" # This example will print out the the OPC item path for each item in a specific folder, # Browse Ignition's OPC UA Server. This can be changed to match any connected OPC server. server = "Ignition OPC UA Server" # Focus on the "SLC" device connection. This must match a valid device connection in the OPC server. device = "SLC" # Specify that the folder path should contain "B3". folderPath = "*B3*" # This example is not filtering on a specific OPCItemPath, so it pass Python's None for this parameter opcItemPath = None # Call browseSimple and store the results in a variable. Note that it may take some time to complete the browse. OpcObjects = system.opc.browseSimple(server, device, folderPath, opcItemPath) # For each returned address, print out the for address in OpcObjects: print address.getOpcItemPath() ```
