--- title: "system.net.httpPut" description: "Performs an HTTP PUT to the given URL." --- # system.net.httpPut > Performs an HTTP PUT to the given URL. This function is used in **Python Scripting**. ## Description Performs an HTTP PUT to the given URL. Encodes the given dictionary of parameters using "applications/x-www-form-urlencoded" format. Keep in mind that [JRE proxy settings](https://docs.oracle.com/en/java/javase/11/docs/api/java.base/java/net/doc-files/net-properties.html#Proxies) will influence how these functions conduct their network activities. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax :::tip This function accepts [keyword arguments](platform/scripting/python-scripting/user-defined-functions.md#keyword-arguments). ::: `system.net.httpPut(url, [contentType], putData, [connectTimeout], [readTimeout], [username], [password], [headerValues], [bypassCertValidation])` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `url` | The URL to put to. String| `contentType` | The MIME type used in the HTTP 'Content-type' header. [optional] String| `putData` | The raw data to put via HTTP. Int| `connectTimeout` | The timeout for connecting to the URL in milliseconds. Default is 10,000. [optional] Int| `readTimeout` | The read timeout for the operation in milliseconds. Default is 60,000. [optional] String| `username` | If specified, the call will attempt to authenticate with basic HTTP authentication. [optional] String| `password` | The password used for basic HTTP authentication, if the username parameter is also present. [optional] Dictionary[String, String]| `headerValues` | A dictionary of name/value pairs that will be set in the HTTP header. [optional] Boolean| `bypassCertValidation` | If the target address in an HTTPS address, and this parameter is true, the system will bypass all SSL certificate validation. This is not recommended, though is sometimes necessary for self-signed certificates. [optional] ### Returns **String** - The content returned for the PUT operation. ### Scope Gateway, Vision Client, Perspective Session ## Syntax `system.net.httpPut(url, putParams)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `url` | The URL to send the request to. Dictionary[String, Integer]| `putParams` | A dictionary of name/value key pairs to use as the put data. ### Returns **String** - The content returned for the PUT operation. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Code Example - Simple Test" # The following example uses a test URL to echo back the data used in the PUT request. # Test URL courtesy of: # http://stackoverflow.com/questions/5725430/http-test-server-that-accepts-get-post-calls?answertab=votes#tab-top # Specify URL and parameters to pass in the PUT call URL = "http://httpbin.org/put" params = {"testkey":"testValue"} # Make the PUT request and print the results to the console print system.net.httpPut(URL, params) ``` ``` python title="Code Example - Keyword Arguments" """ This example attempts to authenticate with a username and password, as well as specify a MIME type. The Username and password are static in this example, but could easily make use of other components to allow user input or fetch data out of a database instead. """ URL = "http://httpbin.org/put" params = {"testkey":"testValue"} user = "myUser" userPass = "password" # Make the PUT request and print the results to the console print system.net.httpPut(URL, params, username = user, password = userPass, contentType = "text/html") ```
