--- title: "system.net.getRemoteServers" description: "This function returns a List of Gateway Network servers that are visible from the local Gateway." --- # system.net.getRemoteServers > This function returns a List of Gateway Network servers that are visible from the local Gateway. This function is used in **Python Scripting**. ## Description This function returns a list of Gateway Network servers that are visible from the local Gateway. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.net.getRemoteServers([runningOnly])` ### Parameters Type | Parameter | Description ------- | ------- | ------ Boolean | `runningOnly`| If set to true, only servers on the Gateway Network that are running will be returned. Servers that have lost contact with the Gateway Network will be filtered out. [optional] ### Returns **List[String]** - A list of strings representing Gateway Network server IDs. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Code Snippet" # The following will create a list of running servers on the Gateway Network, and show the list in a message box. # Collect the list of running servers runningServers = system.net.getRemoteServers(True) # Initialize the start of the message serverStatusText = "The following servers are running:\n " # Add each running server to the message for server in runningServers: serverStatusText += "%s \n" % server # Show the message system.gui.messageBox(serverStatusText) ```
