system.nav.openWindow
Descriptionβ
Opens the window with the given path. If the window is already open, brings it to the front. The optional params dictionary contains key:value pairs which will be used to set the target window's root container's dynamic variables.
For instance, if the window that you are opening is named TankDisplay and has a dynamic variable in its root container named "TankNumber", then calling system.nav.openWindow("TankDisplay", {"TankNumber" : 4}) will open the TankDisplay window and set root container, TankNumber, to four. This is useful for making parameterized windows, that is, windows that are re-used to display information about like pieces of equipment. See also: Parameterized Popup Windows.
Syntaxβ
system.nav.openWindow(path, [params])
Parametersβ
| String | path | The path to the window to open. |
| Dictionary[String, Any] | params | A dictionary of parameters to pass into the window. The keys in the dictionary must match dynamic property names on the target window's root container. The values for each key will be used to set those properties. [optional] |
Returnsβ
Window - A reference to window that was navigated to. Refer to the list of window objects.
Scopeβ
Vision Client
Code Examplesβ
# This is the simplest form of openWindow.
system.nav.openWindow("SomeWindowName")
# A more complex example - a setpoint screen for multiple valves that opens centered.
titleText = "Third Valve Setpoints"
tankNo = system.nav.openWindow("ValveSetPts", {"valveNum":3, "titleText":titleText})
system.nav.centerWindow("ValveSetPts")
# Opens a popup window, and sets the dimensions to 100 pixels x 100 pixels.
window = system.nav.openWindow("popup")
window.size = (100,100)
Keywordsβ
system nav openWindow, nav.openWindow
