--- title: "system.nav.goHome" description: "When using the Typical Navigation Strategy, this function will navigate to the \"home\" window." --- # system.nav.goHome > When using the Typical Navigation Strategy, this function will navigate to the "home" window. This function is used in **Python Scripting**. ## Description When using the [typical navigation strategy](ignition-modules/vision/vision-windows/navigation-strategies-in-vision/navigation-strategies-in-vision.md), this function will navigate to the "home" window. This is automatically detected as the first main-screen window shown in a project. If you are using this system function with [system.nav.openWindow()](appendix\scripting-functions\system-nav\system-nav-openWindow.md), your home window should be closed before navigating to it, or system.nav.goHome() may not work. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.nav.goHome()` ### Parameters Nothing ### Returns **Window** - A reference to window that was navigated to. Refer to the list of [window](appendix\components\vision-components\vision-window-object\vision-window-object.md) objects. ### Scope Vision Client ## Code Examples ```python title="Example #1" # This code would go in a button to move to the Home screen. system.nav.goHome() ```
