--- title: "system.nav.getCurrentWindow" description: "Returns the path of the current \"main screen\" window, which is defined as the maximized window." --- # system.nav.getCurrentWindow > Returns the path of the current "main screen" window, which is defined as the maximized window. This function is used in **Python Scripting**. ## Description Returns the path of the current "main screen" window, which is defined as the maximized window. With the [Typical Navigation Strategy](ignition-modules/vision/vision-windows/navigation-strategies-in-vision/navigation-strategies-in-vision.md), there is only ever one maximized window at a time. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.nav.getCurrentWindow()` ### Parameters Nothing ### Returns **String** - The path of the current "main screen" window - the maximized window. ### Scope Vision Client ## Code Examples ```python title="Example #1" # This code could run in a global timer script. # After a 5-minute timeout, navigate back to the home screen. if system.util.getInactivitySeconds()>300 and system.nav.getCurrentWindow()!="Home": system.nav.swapTo("Home") ``` ```python title="Example #2" # This code could run in a global timer script. # After a 5-minute timeout, navigate back to the Over screen inside the Main Windows folder. if system.util.getInactivitySeconds()> 500 and system.nav.getCurrentWindow()!="Main Windows/Overview": system.nav.swapTo("Main Windows/Overview") ```
