--- title: "system.nav.closeWindow" description: "Given a window path, or a reference to a window itself, it will close the window." --- # system.nav.closeWindow > Given a window path, or a reference to a window itself, it will close the window. This function is used in **Python Scripting**. ## Description Given a window path, or a reference to a window itself, it will close the window. If the window can't be found, this function will do nothing. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax #1 (FPMIWindow Param) `system.nav.closeWindow(window)` ### Parameters Type | Parameter | Description ------- | ------- | ------ FPMIWindow | `window` | A reference to the window to close. ### Returns Nothing ### Scope Vision Client ## Syntax #2 (String Param) `system.nav.closeWindow(windowPath)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String | `windowPath` | The path of a window to close. ### Returns Nothing ### Scope Vision Client ## Code Examples ```python title="Example #1" # This example gets the window named 'Overview' and then closes it. # If the window isn't open, a warning is shown. try: window = system.gui.getWindow('Overview') system.nav.closeWindow(window) except ValueError: system.gui.warningBox("The Overview window isn't open") ``` ```python title="Example #2" # This example would close the window named 'Overview' in one step. # If the window isn't open, the call to closeWindow will have no effect system.nav.closeWindow('Overview') ```
