--- title: "system.mongodb.replaceOne" description: "Replaces a document in the collection that matches the filter." --- # system.mongodb.replaceOne > Replaces a document in the collection that matches the filter. This function is used in **Python Scripting**. :::note Project Library scripts will not provide hints for MongoDB system functions unless the Script Hint Scope is set to **Gateway**. See the [Scripting in Ignition](platform\scripting\scripting-in-ignition\scripting-in-ignition.md#system-functions-hints-and-autocomplete) page for more details on scripting hints. ::: ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.mongodb.replaceOne(connector, collection, filter, replacement, [options])` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `connector` | The name of connector (case-insensitive). String| `collection` | The name of collection (case-sensitive). PyDictionary| `filter` | A PyDictionary for specifying matching key value pair criteria when querying a collection. PyDictionary| `replacement` | New values to apply for all non-immutable document fields. PyDictionary| `options` | A PyDictionary for including additional replace configurations. [optional] ### Returns **PyDictionary** `result` - Result of replace action formatted as a PyDictionary with keys ‘acknowledged’, ‘modifiedCount’, ‘matchedCount’, and ‘upsertedId’. ### Scope Gateway, Perspective Session ## Code Examples ```python title="Example #1" # Import required BSON types. from system.mongodb.types import ObjectId # Specify unique field values to locate specific document. Here we are specifying the known _id of the document. filter = {"_id": ObjectId("63fe3941519feb58abb3cda1")} # Specify required fields in a PyDictionary format for BSON document. replacement = { "username": "jdoe2", "name": "Jane Doe II", "address": '321 Second Street, City CA 56789', "birthdate": system.date.getDate(2004, 5, 19), "email": "jdoe2@email.com", "active": True, "accounts": [], "tier_and_details": {} } # Apply parameters for function call. print system.mongodb.replaceOne("MongoDB", "customers", filter, replacement) ```
