--- title: "system.mongodb.insertOne" description: "Inserts a single PyDictionary into a specified collection." --- # system.mongodb.insertOne > Inserts a single PyDictionary into a specified collection. This function is used in **Python Scripting**. :::note Project Library scripts will not provide hints for MongoDB system functions unless the Script Hint Scope is set to **Gateway**. See the [Scripting in Ignition](platform\scripting\scripting-in-ignition\scripting-in-ignition.md#system-functions-hints-and-autocomplete) page for more details on scripting hints. ::: ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.mongodb.insertOne(connector, collection, document, [options])` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `connector` | The name of connector (case-insensitive). String| `collection` | The name of collection (case-sensitive). PyDictionary| `document` | A PyDictionary of specified fields that will represent a record being added to the collection. [See MongoDB documentation](https://www.mongodb.com/docs/v6.0/core/document/) for more details about documents. PyDictionary| `options` | A PyDictionary for including additional insert configurations. [optional]. ### Returns **PyObject** `objectId` - Key of inserted document. This will usually be BSON document ObjectId, unless a different key type is specified. ### Scope Gateway, Perspective Session ## Importing Classes You can import classes from system.mongodb.types like you would other Python classes: #### Example ``` from system.mongodb.types import ObjectId newObjectId = ObjectId.get() ``` You can also iterate those system.mongodb.types packages to see all available classes: #### Example ``` for d in dir(system.mongodb.types): print d ``` ### API Docs MongoDB-specific data types come from the org.bson.types package of the Mongo Java Driver API. The library of classes available for import can be accessed at this link: [Mongo Java Driver 3.6.0 API Docs for Package org.bson.types](https://mongodb.github.io/mongo-java-driver/3.6/javadoc/org/bson/types/package-summary.html). ## Types References The following values can be referenced for the types parameter at system.mongodb.types: ``` Binary Code CodeWScope CodeWithScope Decimal128 INSTANCE MaxKey MinKey ObjectId Symbol Timestamp ``` ## Code Examples ```python title="Example #1" # Import required BSON types. from system.mongodb.types import ObjectId from system.mongodb.types import Timestamp # Specify required document fields in a PyDictionary format for BSON document. document = { "_id": ObjectId(), "transaction_count": 0, "bucket_start_date": Timestamp(), "bucket_end_date": '', "transactions": [] } # Apply parameters for function call. print system.mongodb.insertOne("MongoDB", "transactions", document) ```
