--- title: "system.math.percentile" description: "Given a sequence of numerical values, estimates the percentile of input." --- # system.math.percentile > Given a sequence of numerical values, estimates the percentile of input. This function is used in **Python Scripting**. ## Description The percentile is a value on a scale that represents a percentage position in a list of data that can be equal to or below that value: i.e., the 25th percentile is a value below which 25% of observable data points may be found. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.math.percentile(values, percentile)` ### Parameters Type | Parameter | Description ------- | ------- | ------ List[Float]| `values` | A sequence of numerical values. Accepts both integers and floats. The sequence may not contain None type values. However, passing a None type object instead of a sequence of numerical values will return NaN. Float| `percentile` | The percentile to compute. A float greater than 0 and less than or equal to 100. Will throw an exception if the percentile is out of bounds. ### Returns **Float** - A value from the given list using the requested percentile of the input, or NaN if the input was empty or null. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1" # Create a list of values. values = [3.5, 5.6, 7.4, 3.8] # Print the 75th percentile. print system.math.percentile(values, 75) ```
