--- title: "system.math.mode" description: "Given a sequence of values, returns the 'mode', or most frequent values." --- # system.math.mode > Given a sequence of values, returns the 'mode', or most frequent values. This function is used in **Python Scripting**. ## Description Returns an empty list if the sequence was empty or None. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.math.mode(values)` ### Parameters Type | Parameter | Description ------- | ------- | ------ List[Float] | `values` | A sequence of numerical values. Accepts both integers and floats. The sequence may not contain None type values. ### Returns **List[Float]** - A Java Array (functionally similar to a Python List) of floats representing the most frequent value(s) in the values parameter. If the values parameter was empty, then an empty list will be returned instead. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1 - Getting the Mode from a List of Values" # Create a list of values. values = [3.5, 5.6, 7.8, 7.4, 7.8] # Return the most common values. modes = system.math.mode(values) # Print the first item in the result. print modes[0] # Iterate over the results. for number in modes: print number ```
