--- title: "system.math.kurtosis" description: "Calculates the kurtosis of a sequence of values." --- # system.math.kurtosis > Calculates the kurtosis of a sequence of values. This function is used in **Python Scripting**. ## Description Calculates the kurtosis of a sequence of values. Kurtosis measures if data is peaked or flat relative to normal distribution. A set of data with high kurtosis will have distinct peaks near the mean, while a set of data with low kurtosis will have a flat top near the mean. Uniform distribution is typically a flat line. Returns NaN (Not a Number) if passed an empty sequence measure of whether the data are heavy-tailed or light-tailed of a given distribution. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.math.kurtosis(values)` ### Parameters Type | Parameter | Description ------- | ------- | ------ List[Float] | `values` | A sequence of numerical values. Accepts both integers and floats. The sequence may not contain None type values. However, passing a None type object instead of a sequence of numerical values will return NaN. Requires at least four items in the list. ### Returns **Float** - The kurtosis, or NaN if the input was empty or null. Additionally, returns NaN if the values returned fewer than four values. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1" # Create a List of values. values = [3.5, 5.6, 7.8, 7.4, 3.8] # Prints the resulting value. print system.math.kurtosis(values) ```
