--- title: "system.gui.inputBox" description: "Opens up a popup input dialog box." --- # system.gui.inputBox > Opens up a popup input dialog box. This function is used in **Python Scripting**. ## Description Opens up a popup input dialog box. This dialog box will show a prompt message and allow the user to type in a string. When the user is done, they can click **OK** or **Cancel**. If OK is pressed, this function will return with the value that they typed in. If Cancel is pressed, this function will return the value None. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.gui.inputBox(message, defaultText)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `message` | The message to display for the input box. Will accept HTML formatting. String| `defaultText` | The default text to initialize the input box with. ### Returns **String** - The string value that was entered in the input box. ### Scope Vision Client ## Code Examples ```python title="Example #1" # In the mouseClicked event of a label, this allows the user to change the label's text. txt = system.gui.inputBox("Enter text:", event.source.text) if txt != None: event.source.text = txt ```
