--- title: "system.gui.getWindow" description: "Finds a reference to an open window with the given name." --- # system.gui.getWindow > Finds a reference to an open window with the given name. This function is used in **Python Scripting**. ## Description Finds a reference to an open window with the given name. Throws a ValueError if the named window is not open or not found. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.gui.getWindow(name)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `name` | The path to the window to field. ### Returns **Window** - A reference to the [window](appendix\components\vision-components\vision-window-object\vision-window-object.md) object, if it was open. ### Scope Vision Client ## Code Examples ```python title="Example #1" # This example will get the window named 'Overview' and then close it. try: window = system.gui.getWindow('Overview') system.gui.closeWindow(window) except ValueError: system.gui.warningBox("The Overview window isn't open") ``` ```python title="Example #2" # This example will set a value on a label component in the 'Header' window. try: window = system.gui.getWindow('Header') window.getRootContainer().getComponent('Label').text = "Machine 1 Starting" except ValueError: system.gui.warningBox("The Header window isn't open") ```
