--- title: "system.gui.getSibling" description: "Given a component event object, looks up a sibling component." --- # system.gui.getSibling > Given a component event object, looks up a sibling component. This function is used in **Python Scripting**. ## Description Given a component event object, looks up a sibling component. Shortcut for [event.source.parent.getComponent("siblingName")](ignition-modules\vision\scripting-in-vision\component-events\component-events.md). If no such sibling is found, the special value None is returned. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.gui.getSibling(event, name)` ### Parameters Type | Parameter | Description ------- | ------- | ------ EventObject| `event` | A component event object. String| `name` | The name of the sibling component. ### Returns **VisionComponent** - Returns reference to the sibling component. See [VisionComponent](https://sdk.inductiveautomation.com/javadoc/ignition81/latest/com/inductiveautomation/vision/api/client/components/model/VisionComponent.html). ### Scope Vision Client ## Code Examples ```python title="Example #1" # This example gets its sibling Text Field's text, and uses it. textField = system.gui.getSibling(event, 'TextField (1)') if textField is None: system.gui.errorBox("There is no text field!") else: system.gui.messageBox("You typed: %s" % textField.text) ```
