--- title: "system.gui.getQuality" description: "Returns the data quality for the property of the given component as an integer." --- # system.gui.getQuality > Returns the data quality for the property of the given component as an integer. This function is used in **Python Scripting**. ## Description Returns the data quality for the property of the given component as an integer. This function can be used to check the quality of a Tag binding on a component in the middle of the script so that alternative actions can be taken in the event of device disconnections. A description of the quality codes can be found on the [Quality Codes and Overlays](platform\tags\quality-codes-and-overlays\quality-codes-and-overlays.md) page. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.gui.getQuality(component, propertyName)` ### Parameters Type | Parameter | Description ------- | ------- | ------ JComponent| `component` | The component whose property is being checked. String| `propertyName` | The name of the property as a string value. ### Returns **Integer** - The data quality of the given property as an integer. ### Scope Vision Client ## Code Examples ```python title="Example #1" # The following code checks the quality code on an component. If a quality is anything other than good, a message appears. # Fetch the quality code from the Value property on a Numeric Label. The Numeric Label in this example is inside the same container as this script. qualityCode = system.gui.getQuality(event.source.parent.getComponent('Numeric Label'), "value") # Evaluate the quality code. If a value other than 192 is returned: if str(qualityCode) == "Good": # The quality code is good, so continue working. This example simply shows a message, but could be modified to do something more meaningful system.gui.messageBox("The property is showing good quality") else: # ...then show a message informing the user. Using Python's string formatting (%i) to pass the quality code into the message. system.gui.messageBox("Operation Aborted \n The associated tag is showing quality code %s \n Please check the device connection" % qualityCode) ```
