--- title: "system.gui.convertPointToScreen" description: "Converts a pair of coordinates that are relative to the upper-left corner of a component to be relative to the upper-left corner of the entire screen." --- # system.gui.convertPointToScreen > Converts a pair of coordinates that are relative to the upper-left corner of a component to be relative to the upper-left corner of the entire screen. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.gui.convertPointToScreen(x, y, event)` ### Parameters Type | Parameter | Description ------- | ------- | ------ Integer| `x` | The X-coordinate, relative to the component that fired the event. Integer| `y` | The Y-coordinate, relative to the component that fired the event. EventObject| `event` | An event object for a component event. ### Returns **Tuple** - A tuple of (x,y) in screen coordinates. ### Scope Vision Client ## Code Example ```python title="Code Snippet - Getting Location of Mouse Click" # This example gets the coordinates where the mouse is (from the corner of the monitor) and displays them in a label. # Get the screen coordinates of the pointer and write them to a label. # For this example, the code was placed on the root container of a window under the mouseClicked event handler. coords = system.gui.convertPointToScreen(event.x, event.y, event) event.source.getComponent('Label').text = "x: %s y: %s" %(coords[0], coords[1]) ```
