--- title: "system.gui.closeDesktop" description: "Allows you to close any of the open desktops associated with the current client." --- # system.gui.closeDesktop > Allows you to close any of the open desktops associated with the current client. This function is used in **Python Scripting**. ## Description Allows you to close any of the open desktops associated with the current client. See the [Multi-Monitor Clients](ignition-modules\vision\common-tasks-in-vision\multi-monitor-clients\multi-monitor-clients.md) page for more details about using multiple monitors. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.gui.closeDesktop(handle)` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `handle` | The handle for the desktop to close. The screen index cast as a string may be used instead of the handle. If omitted, this will default to the primary desktop. Alternatively, the handle "primary" can be used to refer to the primary desktop. ### Returns Nothing ### Scope Vision Client ## Code Examples ```python title="Example #1" # The following example will close this desktop system.gui.closeDesktop() ``` ```python title="Example #2" # The following example will close desktop 2 # The handle must be a string system.gui.closeDesktop("2") ``` ```python title="Example #3" # The following example will close the desktop named "Left Monitor" system.gui.closeDesktop("Left Monitor") ```
