--- title: "system.dnp3.selectOperateAnalog" description: "Issues a Select-And-Operate command to set an analog value in an analog output point." --- # system.dnp3.selectOperateAnalog > Issues a Select-And-Operate command to set an analog value in an analog output point. :::note The following function uses [system.dnp3](appendix\scripting-functions\system-dnp3\system-dnp3.md) and the [Legacy DNP3 driver](ignition-modules\opc-ua\opc-ua-drivers\dnp3\legacy-dnp3-driver\legacy-dnp3-driver.md). See [system.dnp](appendix\scripting-functions\system-dnp\system-dnp.md) for [DNP3](ignition-modules\opc-ua\opc-ua-drivers\dnp3\dnp3.md) functions using the [DNP3 driver](ignition-modules\opc-ua\opc-ua-drivers\dnp3\dnp3-driver\dnp3-driver.md). ::: This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions [Permission Type](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties): DNP3 Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.dnp3.selectOperateAnalog(deviceName, index, value, [variation])` ### Parameters Type | Parameter | Description ------- | ------- | ----- String| `deviceName` | The name of the DNP3 device driver. Integer| `index` | The index of the object to be modified in the outstation. Numeric| `value` | The analog value that is requested (of type int, short, float, or double). Integer| `variation` | The DNP3 object variation to use in the request. [optional] ### Returns The DNP3 [status code](system-dnp3.md#status-codes) of the response, as an integer. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1" # This example shows setting the analog output at index 0 to the Double value 3.14 system.dnp3.selectOperateAnalog("Dnp3", 0, 3.14) ``` ```python title="Example #2" # This example shows setting the analog output at index 2 to the Integer value 300 system.dnp3.selectOperateAnalog("Dnp3", 2, 300) ``` ```python title="Example #3" # This example shows setting the analog output at index 15 to the Short value 33. The value sent in the request is converted for the object variation, 2. system.dnp3.selectOperateAnalog("Dnp3", 15, 33.3333, 2) ``` ```python title="Example #4" # This example shows setting the analog output at index 1 to the Float value 15.0. The value sent in the request is converted for the object variation, 3. system.dnp3.selectOperateAnalog("Dnp3", 1, 15, 3) ```
