--- title: "system.dnp3.directOperateBinary" description: "Issues a Direct-Operate command for digital control operations at binary output points (CROB)." --- # system.dnp3.directOperateBinary > Issues a Direct-Operate command for digital control operations at binary output points (CROB). :::note The following function uses [system.dnp3](appendix\scripting-functions\system-dnp3\system-dnp3.md) and the [Legacy DNP3 driver](ignition-modules\opc-ua\opc-ua-drivers\dnp3\legacy-dnp3-driver\legacy-dnp3-driver.md). See [system.dnp](appendix\scripting-functions\system-dnp\system-dnp.md) for [DNP3](ignition-modules\opc-ua\opc-ua-drivers\dnp3\dnp3.md) functions using the [DNP3 driver](ignition-modules\opc-ua\opc-ua-drivers\dnp3\dnp3-driver\dnp3-driver.md). ::: This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions [Permission Type](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties): DNP3 Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.dnp3.directOperateBinary(deviceName, indexes, opType, tcCode, count, onTime, offTime)` ### Parameters Type | Parameter | Description ------- | ------- | ----- String| `deviceName` | The name of the DNP3 device driver. List| `indexes` | A list of indexes of the objects to be modified in the outstation. Integer| `opType` | The type of the operation. 0=NUL, 1=PULSE_ON, 2=PULSE_OFF, 3=LATCH_ON, 4=LATCH_OFF Integer| `tcCode` | The Trip-Close code, used in conjunction with the opType. 0=NUL, 1=CLOSE, 2=TRIP Integer| `count` | The number of times the outstation shall execute the operation. Long| `onTime` | The duration that the output drive remains active, in millis. [optional] Long| `offTime` | The duration that the output drive remains non-active, in millis. [optional] ### Returns The DNP3 [status code](system-dnp3.md#status-codes) of the response, as an integer. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1" # This example shows latching off 3 binary output points with the Direct-Operate command. off = system.dnp3.LATCH_OFF system.dnp3.directOperateBinary("Dnp3", [0, 1, 2], off) ``` ```python title="Example #2" # This example shows setting a binary output point at index 3 to pulse at 5 second intervals # with the Direct-Operate command. pulse = system.dnp3.PULSE_OFF trip = system.dnp3.TRIP system.dnp3.directOperateBinary("Dnp3", [3], pulse, trip, 5000, 5000) ```
