system.dnp.directOperateBinary
note
The following function uses system.dnp and the DNP3 driver. For system.dnp3 functions and the Legacy DNP3 driver, see DNP3.
Descriptionβ
Performs a Direct Operate command on a binary point.
Syntaxβ
system.dnp.directOperateBinary(deviceName, index, tcc, opType, count, onTime, offTime)
Parametersβ
| String | deviceName | The name of the DNP3 device instance. |
| Integer | index | The index of the binary point. |
| Integer | tcc | Trip Close Code: 0=NUL, 1=CLOSE, 2=TRIP. |
| Integer | opType | Operation Type: 0=NUL, 1=PULSE_ON, 2=PULSE_OFF, 3=LATCH_ON, 4=LATCH_OFF. |
| Integer | count | The number of times the outstation shall execute the operation. |
| Integer | onTime | Duration (in milliseconds) the output drive remains active. |
| Integer | offTime | Duration (in milliseconds) the output drive remains non-active. |
Returnsβ
Nothing.
Scopeβ
Gateway
Code Examplesβ
Code Snippet
system.dnp.directOperateBinary("DNP3", 3, 1, 3, 2, 5000, 5000)
