--- title: "system.device.setDeviceEnabled" description: "Enables/disables a device in Ignition." --- # system.device.setDeviceEnabled > Enables/disables a device in Ignition. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions [Permission Type](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties): Device Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.device.setDeviceEnabled(deviceName, enabled)` ### Parameters Type | Parameter | Description ------- | ------- | ----- String| `deviceName` | The name of the device in Ignition. Boolean| `enabled` | Specifies whether the device connection will be set to enabled or disabled state. ### Returns Nothing ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Code Snippet" # Example 1: Enable a device system.device.setDeviceEnabled("CLX", 1) ``` ```python title="Code Snippet" # Example 2: Disable a device system.device.setDeviceEnabled("CLX", 0) ```
