--- title: "system.device.addDevice" --- # system.device.addDevice > This function is used in **Python Scripting**. ## Description Adds a new device connection in Ignition. Accepts a dictionary of parameters to configure the connection. Acceptable parameters differ by device type: i.e., a Modbus/TCP connection requires a hostname and port, but a simulator doesn't require any parameters. :::info When using this function, the arguments **MUST** be passed in as [keyword arguments](platform\scripting\python-scripting\user-defined-functions.md#keyword-arguments). ::: ## Client Permission Restrictions [Permission Type](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties): Device Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.device.addDevice(deviceType, deviceName, deviceProps, [description])` ### Parameters Type | Parameter | Description ------- | ------- | ----- String | `deviceType` | The device driver type. Possible values are listed in the Device Types table below. String | `deviceName` | The name that will be given to the new device connection. Dictionary[String, Any] | `deviceProps` | A dictionary of device connection properties and values. Each deviceType has different properties, but most require at least a hostname. Keys in the dictionary are case-insensitive, spaces are omitted, and the names of the properties that appear when manually creating a device connection. String | `description` | The description that will be given to the new device connection. [optional] ### Returns Nothing ### Scope Gateway, Vision Client, Perspective Session ### Device Types The tables below represent Inductive Automation device types that can be created with this function. Some device types require manual configurations to become fully functional, such as loading configuration files or adding mapped entries. In these cases you won't be able to completely configure the device with this function alone. Those device types are marked with "(requires manual configuration)" in the table below. In addition, this function can also add devices from 3rd party modules; you will need to supply the driver type, which the module developer will be able to provide. | Driver Name | Device Type | | ------------------------------------------------- | ----------------------------------------------- | | Allen-Bradley Logix Driver | LogixDriver | | Allen-Bradley Micro800 | com.inductiveautomation.Micro800DeviceType | | Allen-Bradley MicroLogix | MicroLogix | | Allen-Bradley PLC5 | PLC5 | | Allen-Bradley SLC | SLC | | DNP3 Driver | com.inductiveautomation.Dnp3DeviceType | | Legacy DNP3 Driver | Dnp3Driver | | Legacy Allen-Bradley CompactLogix | CompactLogix | | Legacy Allen-Bradley ControlLogix | ControlLogix | | Mitsubishi TCP | com.inductiveautomation.MitsubishiTcpDeviceType | | Modbus RTU | ModbusRtu | | Modbus RTU over TCP | ModbusRtuOverTcp | | Modbus TCP | ModbusTcp | | Omron FINS TCP**(requires manual configuration)** | com.inductiveautomation.FinsTcpDeviceType | | Omron FINS UDP**(requires manual configuration)** | com.inductiveautomation.FinsUdpDeviceType | | Omron NJ Driver | com.inductiveautomation.omron.NjDriver | | IEC 61850 Driver | com.inductiveautomation.Iec61850DeviceType | |Siemens S7-300| S7300| |Siemens S7-400| S7400| |Siemens S7-1200| S71200| |Siemens S7-1500 |S71500| |Simulators Dairy Demo Simulator| DairyDemoSimulator| |Simulators Generic Simulator| Simulator| |Simulators SLC Simulator| SLCSimulator| |TCP Driver |TCPDriver| |UDP Driver| UDPDriver| ### Device Properties The `deviceProps` parameter is where you supply configuration values to the new connection. Value properties depend on which deviceType was specified. A listing of deviceProps keys can be found on the [system.device.addDevice - deviceProps Listing](appendix\scripting-functions\system-device\system-device-addDevice\system-device-addDevice-deviceProps-Listing.md) page. The keys in the `deviceProps` parameter are **case-insensitive**. Device properties not specified in the deviceProps parameter will fallback to default values if not specified (where applicable: i.e., "hostname" typically does not have a default value). ## Code Examples ```python title="Code Snippet - Creating a New Simulator Device" # Below is an example of creating a new Generic Simulator device connection. # Note that we MUST pass a dictionary as the 3rd parameter, even if it's empty. # Call the function system.device.addDevice(deviceType = "Simulator", deviceName = "New_Generic_Simulator", deviceProps = {} ) ``` ```python title="Code Snippet - Creating a New Allen Bradley Logix Device" # Add a device using the Allen-Bradley Logix Driver for firmware v21+ devices deviceProps = {} deviceProps["Hostname"] = "192.168.1.2" system.device.addDevice(deviceName="Test1", deviceType="LogixDriver", deviceProps=deviceProps) ``` ```python title="Code Snippet - Creating a New Siemens Device" # Below is an example of creating a new S7-1500 device connection. # Build a Dictionary of parameters newProps = { "HostName" : "10.0.0.1", "Port" : 102 # <---If adding additional parameters, make sure to add a comma. } # Call the function system.device.addDevice(deviceType = "S71500", \ deviceName = "My_S7_1500_Device",\ deviceProps = newProps ) ``` ```python title="Code Snippet - Creating a New Device in a Disabled State" # Add a Simulator device in a disabled state # Define your dictionary. This is where the device will know whether to be added in a disabled or enabled state. # A value of 0 will add the device in a disabled state, while a value of 1 will add the device in an enabled state. newProps = { "Enabled" : 0 } # Call the system function system.device.addDevice(deviceType = "Simulator", deviceName = "MySimDevice", deviceProps = newProps) ```
