--- title: "system.db.setDatasourceEnabled" description: "Enables/disables a given database connection." --- # system.db.setDatasourceEnabled > Enables/disables a given database connection. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions [Permission Type](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties): Datasource Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.db.setDatasourceEnabled(name, enabled)` ### Parameters Type | Parameter | Description ------- | ------- | ----- String | `name` | The name of the database connection in Ignition. Boolean | `enabled` | Enables/disables a given database connection. ### Returns Nothing ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Code Snippet - Enabling a Database Connection" # Enable the database named "MySQL" system.db.setDatasourceEnabled("MySQL", 1) ``` ```python title="Code Snippet - Disabling a Database Connection" # Disable the database named "MySQL" system.db.setDatasourceEnabled("MySQL", 0) ```
