--- title: "system.db.clearNamedQueryCache" description: "This clears the cache of a Named Query." --- # system.db.clearNamedQueryCache > This clears the cache of a Named Query. This function is used in **Python Scripting**. ## Description This clears the cache of a Named Query. If called from the shared scope (i.e., Tag Event Scripts, Alarm Pipelines, etc.) then the name of the project must be passed as a parameter. ## Client Permission Restrictions This scripting function has no [Client Permission](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax - Project Scope `system.db.clearNamedQueryCache(path)` ### Parameters | Type | Parameter | Description | | ------- | ------- | ----- | | String | `path` | The Path to the named query we want to clear the cache of. | ### Returns No Return Value ### Scope Vision Client, Perspective Session ## Syntax - Shared Scope `system.db.clearNamedQueryCache(project, path)` ### Parameters | Type | Parameter | Description | | ------- | ------- | ----- | | String | `project` | The Project that contains the named query whose cache needs to be cleared. | | String | `path` | The Path to the named query we want to clear the cache of. | ### Returns No Return Value ### Scope Gateway ## Code Examples ```python title="Example - Clear Named Query Cache for a Specific Project" # Calling this simply clears all Named Query caches. # This example is being called from the shared scope. If called from the project scope, the projectName parameter should be omitted. projectName = "myProject" namedQueryPath = "folder/selectFromInventory" system.db.clearNamedQueryCache(projectName, namedQueryPath) ``` ```python title="Example - Clear Named Query Cache" # If the same Named Query is called multiple times with different parameters in a single script, then we can clear the caches once we're done with the following. # This example assumes the script is running in the project scope. If called from the Shared Scope, the name of the project would need to be included. namedQueryPath = "myUpdateQuery" # This creates one cache. params = {"param1":"A"} system.db.runNamedQuery(namedQueryPath, params) # This creates a separate cache. params = {"param1":"B"} system.db.runNamedQuery(namedQueryPath, params) # Clear all of the caches from the specified Named Query. Note that all caches are cleared, including those generated from elsewhere on the Gateway. system.db.clearNamedQueryCache(namedQueryPath) ```
