--- title: "system.date.setTime" description: "Takes in a date, and returns a copy of it with the time fields set as specified." --- # system.date.setTime > Takes in a date, and returns a copy of it with the time fields set as specified. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.date.setTime(date, hour, minute, second)` ### Parameters Type | Parameter | Description ------- | ------- | ------ Date | `date` | The starting date. Integer | `hour` | The hours (0-23) to set. Integer | `minute` | The minutes (0-59) to set. Integer | `second` | The seconds (0-59) to set. ### Returns **Date** - A new date, set to the appropriate time. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Code Snippet" # This example will set the date object to the current date with the time set to 01:37 in the morning and 44 seconds. date = system.date.getDate(2018, 6, 29) #getDate is zero based, so a month parameter of 6 will return July. print system.date.setTime(date, 1, 37, 44) #This will print Sun July 29 01:37:44 PDT 2018 ```
