--- title: "system.date.isDaylightTime" description: "Checks to see if the current timezone is using daylight savings time during the date specified." --- # system.date.isDaylightTime > Checks to see if the current timezone is using daylight savings time during the date specified. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.date.isDaylightTime([date])` ### Parameters Type | Parameter | Description ------- | ------- | ------ Date | `date` | The date you want to check if the current timezone is observing daylight savings time. Uses now() if omitted. [optional] ### Returns **Boolean** - True if date is observing daylight savings time in the current timezone; false otherwise. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Code Snippet" date = system.date.getDate(2018, 6, 28) print system.date.isDaylightTime(date) #Will print True in the US Pacific time zone. ```
