--- title: "system.dataset.updateRow" description: "Takes a dataset and returns a new dataset with a one row altered." --- # system.dataset.updateRow > Takes a dataset and returns a new dataset with a one row altered. This function is used in **Python Scripting**. ## Description Takes a [dataset](platform/scripting/python-scripting/variables-datatypes-and-objects/datasets.md) and returns a new dataset with a one row altered. To alter the row, this function takes a Python dictionary to represent the changes to make to the specified row. The keys in the dictionary are used to find the columns to alter. :::note Datasets are immutable, which means they cannot be directly modified once created. Instead, this scripting function returns a new dataset with some modification applied, which must be assigned to a variable to be used. See [Altering a Dataset](platform/scripting/python-scripting/variables-datatypes-and-objects/datasets.md#altering-a-dataset). ::: ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.dataset.updateRow(dataset, rowIndex, changes)` ### Parameters Type | Parameter | Description ------- | ------- | ------- Dataset | `dataset` | The starting dataset. Will not be modified (datasets are immutable), but acts as the basis for the returned dataset. Integer | `rowIndex` | The index of the row to update (starting at 0). Dictionary[String, Any] | `changes` | A dictionary of changes to make. The keys in the dictionary should match column names in the dataset, and their values will be used to update the row. ### Returns **Dataset** - A new dataset with the values at the specified row updated according to the values in the dictionary. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Code Snippet" # This example could be used to dynamically change the data that an Easy Chart displays. # In this simple example, we assume that the chart is always configured to display a single tank's level. # This script updates the pen being displayed using a dynamic tank number. # Generate new tag name and tag path. tankNumber = 5 newName = "Tank %d Level" % tankNumber newPath = "Tanks/Tank %d/Level" % tankNumber # Consolidate changes into a dictionary. updates = {"NAME": newName, "TAG_PATH":newPath} # Update the Easy Chart. chart = event.source.parent.getComponent("Easy Chart") newPens = system.dataset.updateRow(chart.tagPens, 0, updates) chart.tagPens = newPens ```
