--- title: "system.dataset.toPyDataSet" description: "This function converts from a normal DataSet to a PyDataSet, which is a wrapper class which makes working with datasets more Python-esque." --- # system.dataset.toPyDataSet > This function converts from a normal DataSet to a PyDataSet, which is a wrapper class which makes working with datasets more Python-esque. This function is used in **Python Scripting**. ## Description This function converts from a normal [dataset](platform/scripting/python-scripting/variables-datatypes-and-objects/datasets.md) to a PyDataset, which is a wrapper class which makes working with datasets more Python-esque. For more information on datasets and PyDatasets, see the [Datasets](platform/scripting/python-scripting/variables-datatypes-and-objects/datasets.md) page. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.dataset.toPyDataSet(dataset)` ### Parameters Type | Parameter | Description ------- | ------- | ------- Dataset | `dataset` | A dataset object to convert into a PyDataset. ### Returns **PyDataset** - The newly created PyDataset. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Code Snippet - Summing Values in a Column" # This example script would be added to a button that is in the same container as the table you are working with. # It grabs the data of the Table component, and adds up the values in the first column, displaying the result to the user. # Get a Table component's data. table = event.source.parent.getComponent("Table") data = system.dataset.toPyDataSet(table.data) # Loop through the data, summing the Value column. value = 0.0 for row in data: value += row[0] # Show the user the sum of the Value column. system.gui.messageBox("The value is: %f" % value) ```
