--- title: "system.dataset.setValue" description: "Takes a dataset and returns a new dataset with one value altered." --- # system.dataset.setValue > Takes a dataset and returns a new dataset with one value altered. This function is used in **Python Scripting**. ## Description Takes a [dataset](platform/scripting/python-scripting/variables-datatypes-and-objects/datasets.md) and returns a new dataset with one value altered. :::note Datasets are immutable, which means they cannot be directly modified once created. Instead, this scripting function returns a new dataset with some modification applied, which must be assigned to a variable to be used. See [Altering a Dataset](platform/scripting/python-scripting/variables-datatypes-and-objects/datasets.md#altering-a-dataset). ::: ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax - columnName `system.dataset.setValue(dataset, rowIndex, columnName, value)` ### Parameters Type | Parameter | Description ------- | ------- | ------- Dataset | `dataset` | The starting dataset. Will not be modified (datasets are immutable), but acts as the basis for the returned dataset. Integer | `rowIndex` | The index of the row to set the value at (starting at 0). String | `columnName` | The name of the column to set the value at. Case insensitive. Any | `value` | The new value for the specified row/column. ### Returns **Dataset** - A new dataset, with the new value set at the given location. ### Scope Gateway, Vision Client, Perspective Session ## Syntax - columnIndex `system.dataset.setValue(dataset, rowIndex, columnIndex, value)` ### Parameters Type | Parameter | Description ------- | ------- | ------- Dataset | `dataset` | The starting dataset. Will not be modified (datasets are immutable), but acts as the basis for the returned dataset. Integer | `rowIndex` | The index of the row to set the value at (starting at 0). Integer | `columnIndex` | The index of the column to set the value at (starting at 0) Any | `value` | The new value for the specified row/column. ### Returns **Dataset** - A new dataset, with the new value set at the given location. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Code Snippet" # This snippet demonstrates how to take an initial dataset, set a new value on a new dataset, and then write back to the source of the initial dataset. # In this case we're using a Table component from the Vision module. # Fetch a reference to an existing dataset. table = event.source.parent.getComponent("Table") # Make a new dataset with an updated value newData = system.dataset.setValue(table.data, 3, "lname", 7) # Repalce the table's dataset with our new dataset table.data = newData ``` ```python title="Code Snippet" # This snippet could be used for a Vision Button's actionPerformed event to change the selected cell's value in a Table component to zero. # Fetch table reference table = event.source.parent.getComponent("Table") # Fetch selected row and column selRow = table.getSelectedRow() selCol = table.getSelectedColumn() # If row and column have been selected, update value in table to 0. if selRow != -1 and selCol != -1: newData = system.dataset.setValue(table.data, selRow, selCol, 0.0) table.data = newData ```
